[GRASS-user] algorithm used in i.cluster
Markus Neteler
neteler at osgeo.org
Wed Apr 21 21:48:26 EDT 2010
On Wed, Apr 21, 2010 at 5:29 PM, Georg Kaspar <georg at muenster.de> wrote:
> hi,
> a quote from Markus' "Introduction to GRASS GIS Software" (1998):
> "[...] GRASS uses the "minimum distance to means" algorithm for deriving the
> clusters [...]
This knowledge is essentially based on
http://grass.osgeo.org/grass64/manuals/html64_user/i.cluster.html
and "The GRASS 4 Image Processing manual"
http://grass.itc.it/gdp/imagery/grass4_image_processing.pdf
and
http://trac.osgeo.org/grass/browser/grass/branches/releasebranch_6_4/imagery/i.cluster
http://download.osgeo.org/grass/grass6_progman/c__exec_8c_source.html
-> /* generate class means */
00063 I_cluster_means(C);
etc.
> "minimum distance to means" is described in Lillesand and Kiefer (2000), as
> a supervised classification technique which requires a priori information.
> Does the i.cluster module use a modified version or have there been changes
> since 1998?
To my knowledge, no algorithm changes have been taken place.
> the manual page does not contain any further information on how the module
> works...
Luckily it is open source :)
> does anybody know which exact algorithm is used (k-means probably...)?
I'm afraid that you need to compare it to a k-means algorithm. Please let
us know your findings.
Markus
