[GRASS-user] Fw: Problems importing a common GeoTIFF
Miha Staut
mihastaut at yahoo.co.uk
Fri Apr 23 15:54:31 EDT 2010
I did run 'g.region rast=bla' beforehand. The problem was I missed the fact that a MASK layer was present obviously not including the area of the GeoTIFF layer. Thanks for pointing the possibility of region problems.
Best regards
Miha
--- On Fri, 23/4/10, Markus Neteler <neteler at osgeo.org> wrote:
> From: Markus Neteler <neteler at osgeo.org>
> Subject: Re: [GRASS-user] Fw: Problems importing a common GeoTIFF
> To: "Miha Staut" <mihastaut at yahoo.co.uk>
> Cc: "GRASS user list" <grass-user at lists.osgeo.org>
> Date: Friday, 23 April, 2010, 14:53
> On Fri, Apr 23, 2010 at 1:54 PM, Miha
> Staut <mihastaut at yahoo.co.uk>
> wrote:
> > Dear all,
> > Recently I have installed a fresh installation of
> GRASS 6.4 (weekly snapshot) with gdal-1.7.1 on a regularly
> updated Fedora 12. The import of common geotiff data that
> previously (quite old installation) seemed to work now yield
> empty rasters (r.report => only no data). I tried the
> binary format
> > as well as to single band (grayscale - 8 bit)
> converted tifs. The command used is as plain as it can get.
> >> r.in.gdal in=bla.tif out=bla
> Did you run
> g.region rast=bla -p
> before? r.report is region sensitive.
> Markus
