[GRASS-user] Problems to install Grass7 on Fedora 12 -64
Adalberto da Silva
adalberto_s at uol.com.br
Sat Apr 24 15:14:27 EDT 2010
Dear all,
I am trying to install Grass7 on my Fedora12 but I always have the same
error message:
>[root at localhost GRASS7]# sh
grass-7.0.svn-i686-pc-linux-gnu-24_04_2010-install.sh --help
>GRASS GIS 7.0.svn-i686-pc-linux-gnu-24_04_2010 binary package
installation tool
>Usage: grass-7.0.svn-i686-pc-linux-gnu-24_04_2010-install.sh
grass-7.0.svn-i686-pc-linux-gnu-24_04_2010.tar.gz [dest_dir] [bin_dir]
> with:
> [dest_dir] - optional: FULL path name to the installation
directory
> (default:
/usr/local/grass7.0.svn-i686-pc-linux-gnu-24_04_2010/)
> [bin_dir] - optional: FULL path name to the grass binary directory
> (default: /usr/local/bin/)
> Notes: 1) Only the grass executable file is
stored here
> 2) If you want to change the binary
directory only
> then you need to specify the destination
> directory as well
>You may need login as root for installation.
I was logged as root (in this case, using su in a console window, but I
tried even logged as root on a KDE GUI and logged as root in command
line mode (init3).
Can you point to me what I am doing wrong?
Regards,
Adalberto
