[GRASS-user] Odd scaling issue with ps.map output and ghostscript ps2pdf
Rich Shepard rshepard at appl-ecosys.com
Tue Apr 27 12:34:07 EDT 2010
On Tue, 27 Apr 2010, Tom Russo wrote:
> In this instance I am now completely convinced it's an issue at the print
> shop, probably because I'm trying to use margins that are too small and
> they're "helpfully" adjusting the size of the image to fix my mistake so
> the edges aren't cut off.
Tom,
   It may also be that the printer they're using has non-printing margins
greater than what you specify. Try printing on larger paper (e.g., C size;
they must have a plotter there) and trimming to size after.
Rich
