[GRASS-user] Importing multiple files with r.in.xyz
Micha Silver micha at arava.co.il
Wed Aug 11 08:32:58 EDT 2010
  On 08/11/2010 03:10 PM, Hanlie Pretorius wrote:
> My apologies for my ignorance, but how do I get this to run in Linux?
> Am using Ubuntu 10.04 and GRASS 6.4RC6.
Samber's method will surely work, but you might more simply try as follows:
# start grass in a location which matches the txt file data
# change to the directory where your txt files are, then do
for infile in *.txt; do outrast=`basename ${infile} .txt`; r.in.xyz
in=${infile} out=${outrast} fs=,; done
# that's it ;-)
Micha
> I entered the following into the GRASS text window and am testing it
> with a list of two files (I removed the region settings because the
> files all have the same region, which I have already set):
> GRASS 6.4.0RC6 (world_wgs84):~>  cat lieb_files_test.txt
> 3B42.000201.12.6.nc.lieb.txt
> 3B42.000201.15.6.nc.lieb.txt
> GRASS 6.4.0RC6 (world_wgs84):~>  cat lieb_files_test.txt | while read line; do
>>   echo $line+" being processed"
>> raster=${$line:(-12)} # cut ".nc.lieb.txt" from raster name
>> r.in.xyz --overwrite input=$line output=raster method="mean" type="FCELL" fs=, x=2 y=1 z=3
> As you can see, when I press enter after the r.in.xyz line, I just get
> another prompt.
> Am I supposed to save it to a separate file and run this as a script?
> If so, where should I put this script?
> 2010/8/10, Saber Razmjooei<razmjooeis at faunalia.co.uk>:
>> cat list_of_files.txt | while read line; do
>>      echo $line+"Being processed" # or whaterver you want to do with the
>> $line variable
>>   raster=$line
>>   r.in.xyz -s -g input=$line output=$line>  tmpRegion
>> myregion= ""`head -n 1 tmpRegion`"
>> g.region $myregion
>> r.in.xyz --overwrite input=$line output=$line fs=,
>> done
>> and your list_of_files.txt is
>> raster1
>> raster2
>> Hope that helps
>> Saber
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> This mail was received via Mail-SeCure System.
