[GRASS-user] Importing multiple files with r.in.xyz
Hanlie Pretorius
hanlie.pretorius at gmail.com
Wed Aug 11 08:36:32 EDT 2010
2010/8/11, Vincent Bain <bain at toraval.fr>:
> Hi, short intrusion in this current thread, without knowing exactly what
> it is related to : I only mean to suggest you to close the while loop...
> This prompt ">" means the shell expects the end of your statement ; here
> you should type "done" to close the while instruction.
Adding 'done' worked and I got the script running from the command line.
Thanks to everyone who chipped in.
