[GRASS-user] AdvancedViewshedAnalysis
Rebecca Rennell lostbex at hotmail.com
Sun Aug 15 09:44:10 EDT 2010
> if you want to have it super easy, download and install
> gvSIG OADE 2010:
>   http://www.oadigital.net/software/gvsigoade
Thanks for this - Hadn't come across gvSIG before. No longer part of a department so slightly out of the loop.
Will give it a go.
Cheers
> When you run the installer, make sure to tick all available
> extensions, so you get the SEXTANTE and GRASS geoprocessing tools.
> Full instructions are here:
>   ftp://88.208.250.116/gvSIG_OADE_Installation.pdf
> A quickstart guide for gvSIG is also available:
>   ftp://88.208.250.116/gvSIG_OADE_Quickstart.pdf
> ... but surely, someone at your department is already using gvSIG?
> You can then run a large number of GRASS modules directly via
> the SEXTANTE graphical user interface.
> r.cva and r.promincence are already included.
> Best,
> Ben
> On 08/13/2010 12:38 PM, Rebecca Rennell wrote:
> > Hi GRASS-Users
> > Apologies for cross-posting.
> > My difficulty is with install AdvancedViewshedAnalysis extension using GEM within GRASS 6.4.ORC6
> > command 'gem6' is not recognised
> > command 'gem install AdvancedViewshedAnalysis.tar' produces the following error message
> > ERROR:  Could not find a valid gem 'AdvancedViewshedAnalysis.tar' (>= 0) in any repository
> > I have an older version of GRASS (GRASS 6.3.0). From here the command
> > 'gem6 -i AdvancedViewshedAnalysis.tar -v' begins to install and then aborts with the following error message:
> > ERROR: Compilation failed for these module(s):
> > /private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.cva
> > /private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.prominence
> > Run 'make' manually in each module's directory for details.
> > make: *** [default] Error 1
> > I've now run make in both modules (I think), but I still get the same error message.  I also don't understand why the tar file is recognised from GRASS 6.3 but not 6.4. I'm almost certainly doing something very stupid - any help gratefully received!
> > Thanks
> > Becky
> > grass-user at lists.osgeo.org
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100815/726b1663/attachment.html
