[GRASS-user] AdvancedViewshedAnalysis
Rebecca Rennell lostbex at hotmail.com
Fri Aug 20 05:44:22 EDT 2010
I've now downloaded gvSIG OADE 2010. Thanks for putting me on to this by the way.... it's brilliant!
However, I'm struggling to setup GRASS in SEXTANTE settings window. Doesn't recognise GRASS GIS installation folder (error message 'The selected folder does not contain a valid GRASS installation') .... or perhaps what i mean is that I don't know where the GRASS installation folder is on the mac. I've tried several different options, but all give same error message.
Any help would be great.
CheersBecky
Dr Rebecca RennellUist Archaeologywww.uistarchaeology.combecky at uistarchaeology.com
> Date: Fri, 13 Aug 2010 15:45:05 +0100
> From: benjamin.ducke at oxfordarch.co.uk
> To: grass-user at lists.osgeo.org
> Subject: Re: [GRASS-user] AdvancedViewshedAnalysis
> Hi Becky,
> if you want to have it super easy, download and install
> gvSIG OADE 2010:
>   http://www.oadigital.net/software/gvsigoade
> When you run the installer, make sure to tick all available
> extensions, so you get the SEXTANTE and GRASS geoprocessing tools.
> Full instructions are here:
>   ftp://88.208.250.116/gvSIG_OADE_Installation.pdf
> A quickstart guide for gvSIG is also available:
>   ftp://88.208.250.116/gvSIG_OADE_Quickstart.pdf
> ... but surely, someone at your department is already using gvSIG?
> You can then run a large number of GRASS modules directly via
> the SEXTANTE graphical user interface.
> r.cva and r.promincence are already included.
> Best,
> Ben
> On 08/13/2010 12:38 PM, Rebecca Rennell wrote:
> > Hi GRASS-Users
> > Apologies for cross-posting.
> > My difficulty is with install AdvancedViewshedAnalysis extension using GEM within GRASS 6.4.ORC6
> > command 'gem6' is not recognised
> > command 'gem install AdvancedViewshedAnalysis.tar' produces the following error message
> > ERROR:  Could not find a valid gem 'AdvancedViewshedAnalysis.tar' (>= 0) in any repository
> > I have an older version of GRASS (GRASS 6.3.0). From here the command
> > 'gem6 -i AdvancedViewshedAnalysis.tar -v' begins to install and then aborts with the following error message:
> > ERROR: Compilation failed for these module(s):
> > /private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.cva
> > /private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.prominence
> > Run 'make' manually in each module's directory for details.
> > make: *** [default] Error 1
> > I've now run make in both modules (I think), but I still get the same error message.  I also don't understand why the tar file is recognised from GRASS 6.3 but not 6.4. I'm almost certainly doing something very stupid - any help gratefully received!
> > Thanks
> > Becky
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100820/4fb3bf18/attachment.html
