[GRASS-user] AdvancedViewshedAnalysis
Benjamin Ducke
benjamin.ducke at oxfordarch.co.uk
Fri Aug 20 05:55:14 EDT 2010
Hi Becky,
The installation manual:
ftp://88.208.250.116/gvSIG_OADE_Installation.pdf
has some details about setting up the software on the Mac.
See section "4":
If you have ticked the "GRASS GIS" option in the installer,
then the folder you need to specify is within the App folder
of gvSIG OADE 2010 on your Mac: "Contents/Resources/grass".
If you are using a Mac, you should definitely read through
the Mac specific section of the PDF manual above and
also the Mac section on the support page here:
http://www.oadigital.net/software/gvsigoade/gvsigbugs
This version of gvSIG has been developed to run on Mac OS X
Snow Leopard and Intel hardware. Anything older than that
will probably require some extra fiddling to make it work.
Best,
Ben
----- Original Message -----
> I've now downloaded gvSIG OADE 2010. Thanks for putting me on to this
> by the way.... it's brilliant!
> However, I'm struggling to setup GRASS in SEXTANTE settings window.
> Doesn't recognise GRASS GIS installation folder (error message 'The
> selected folder does not contain a valid GRASS installation') .... or
> perhaps what i mean is that I don't know where the GRASS installation
> folder is on the mac. I've tried several different options, but all
> give same error message.
> Any help would be great.
> Cheers
> Becky
> Dr Rebecca Rennell
> Uist Archaeology
> www.uistarchaeology.com becky at uistarchaeology.com
> > Date: Fri, 13 Aug 2010 15:45:05 +0100
> > From: benjamin.ducke at oxfordarch.co.uk
> > To: grass-user at lists.osgeo.org
> > Subject: Re: [GRASS-user] AdvancedViewshedAnalysis
> > Hi Becky,
> > if you want to have it super easy, download and install
> > gvSIG OADE 2010:
> > When you run the installer, make sure to tick all available
> > extensions, so you get the SEXTANTE and GRASS geoprocessing tools.
> > Full instructions are here:
> > A quickstart guide for gvSIG is also available:
> > ftp://88.208.250.116/gvSIG_OADE_Quickstart.pdf
> > ... but surely, someone at your department is already using gvSIG?
> > You can then run a large number of GRASS modules directly via
> > the SEXTANTE graphical user interface.
> > r.cva and r.promincence are already included.
> > Best,
> > Ben
> > On 08/13/2010 12:38 PM, Rebecca Rennell wrote:
> > > Hi GRASS-Users
> > > Apologies for cross-posting.
> > > My difficulty is with install AdvancedViewshedAnalysis extension
> > > using GEM within GRASS 6.4.ORC6
> > > command 'gem6' is not recognised
> > > command 'gem install AdvancedViewshedAnalysis.tar' produces the
> > > following error message
> > > ERROR: Could not find a valid gem 'AdvancedViewshedAnalysis.tar'
> > > (>= 0) in any repository
> > > I have an older version of GRASS (GRASS 6.3.0). From here the
> > > command
> > > 'gem6 -i AdvancedViewshedAnalysis.tar -v' begins to install and
> > > then aborts with the following error message:
> > > ERROR: Compilation failed for these module(s):
> > > /private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.cva
> > > /private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.prominence
> > > Run 'make' manually in each module's directory for details.
> > > make: *** [default] Error 1
> > > I've now run make in both modules (I think), but I still get the
> > > same error message. I also don't understand why the tar file is
> > > recognised from GRASS 6.3 but not 6.4. I'm almost certainly doing
> > > something very stupid - any help gratefully received!
> > > Thanks
> > > Becky
> > > _______________________________________________ grass-user mailing
> > > list grass-user at lists.osgeo.org
> > > http://lists.osgeo.org/mailman/listinfo/grass-user
> > ------ Files attached to this email may be in ISO 26300 format
> > (OASIS Open Document Format). If you have difficulty opening them,
> > please visit http://iso26300.info for more information.
Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening them, please visit http://iso26300.info for more information.
