[GRASS-user] AdvancedViewshedAnalysis
Rebecca Rennell
lostbex at hotmail.com
Fri Aug 20 07:04:10 EDT 2010
Thanks for both your suggestions. However, copying '/Applications/gvsig-oade-2010-1.0.0/gvSIG-OADE-2010.app/Contents/Resources/grass' still does not work.
Will email gvSIG & Sextante lists as suggested.
CheersBecky
> From: Agustin.Diez at uv.es
> To: lostbex at hotmail.com; grass-user at lists.osgeo.org
> Subject: RE: [GRASS-user] AdvancedViewshedAnalysis
> Date: Fri, 20 Aug 2010 12:52:35 +0200
> Rebeca,
> Maybe this will help you.
> http://gvsigmac.blogspot.com/2010/07/gvsig-oa-digital-edition-2010-10-just.html
> If not I suggest to write to gvSIG list for further help.
> gvsig_internacional at listserv.gva.es
> Agustin
> PS Copy the following in your grass folder path
> > I've now downloaded gvSIG OADE 2010. Thanks for putting me on to this by the way.... it's brilliant!
> > However, I'm struggling to setup GRASS in SEXTANTE settings window. Doesn't recognise GRASS GIS installation folder
> (error message 'The selected folder does not contain a valid GRASS installation') .... or perhaps what i mean is that I
> don't know where the GRASS installation folder is on the mac. I've tried several different options, but all give same
> error message.
> > Any help would be great.
> > CheersBecky
> > Dr Rebecca RennellUist Archaeologywww.uistarchaeology.combecky at uistarchaeology.com
> > > Date: Fri, 13 Aug 2010 15:45:05 +0100
> > > From: benjamin.ducke at oxfordarch.co.uk
> > > To: grass-user at lists.osgeo.org
> > > Subject: Re: [GRASS-user] AdvancedViewshedAnalysis
> > > Hi Becky,
> > > if you want to have it super easy, download and install
> > > gvSIG OADE 2010:
> > > http://www.oadigital.net/software/gvsigoade
> > > When you run the installer, make sure to tick all available
> > > extensions, so you get the SEXTANTE and GRASS geoprocessing tools.
> > > Full instructions are here:
> > > ftp://88.208.250.116/gvSIG_OADE_Installation.pdf
> > > A quickstart guide for gvSIG is also available:
> > > ftp://88.208.250.116/gvSIG_OADE_Quickstart.pdf
> > > ... but surely, someone at your department is already using gvSIG?
> > > You can then run a large number of GRASS modules directly via
> > > the SEXTANTE graphical user interface.
> > > r.cva and r.promincence are already included.
> > > Best,
> > > Ben
> > > On 08/13/2010 12:38 PM, Rebecca Rennell wrote:
> > > > Hi GRASS-Users
> > > > Apologies for cross-posting.
> > > > My difficulty is with install AdvancedViewshedAnalysis extension using GEM within GRASS 6.4.ORC6
> > > > command 'gem6' is not recognised
> > > > command 'gem install AdvancedViewshedAnalysis.tar' produces the following error message
> > > > ERROR: Could not find a valid gem 'AdvancedViewshedAnalysis.tar' (>= 0) in any repository
> > > > I have an older version of GRASS (GRASS 6.3.0). From here the command
> > > > 'gem6 -i AdvancedViewshedAnalysis.tar -v' begins to install and then aborts with the following error message:
> > > > ERROR: Compilation failed for these module(s):
> > > > /private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.cva
> > > > /private/tmp/grass.extension.Mngj89/AdvancedViewshedAnalysis/src/raster/r.prominence
> > > > Run 'make' manually in each module's directory for details.
> > > > make: *** [default] Error 1
> > > > I've now run make in both modules (I think), but I still get the same error message. I also don't understand why
> the tar file is recognised from GRASS 6.3 but not 6.4. I'm almost certainly doing something very stupid - any help
> gratefully received!
> > > > Thanks
> > > > Becky
> > > > _______________________________________________
> > > > grass-user mailing list
> > > > http://lists.osgeo.org/mailman/listinfo/grass-user
> > > Files attached to this email may be in ISO 26300 format (OASIS Open Document Format). If you have difficulty opening
> them, please visit http://iso26300.info for more information.
> Dr. Agustín Diez Castillo
> Departament de Prehistòria i Arqueologia
> Phone: +34 963 86 42 42
> Avda. Blasco Ibañez, 28 Fax: +34 963 86 42 34
> València 46010
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100820/14d62d21/attachment.html
