[GRASS-user] Displaying layers - GRASS 6.4.0RC7 with MSYS
Chethan S
chethanuniversal at gmail.com
Sun Aug 29 09:45:00 EDT 2010
On Sun, Aug 29, 2010 at 6:43 PM, Glynn Clements <glynn at gclements.plus.com>wrote:
> Chethan S wrote:
> > I natively use GRASS in ubuntu but wanted to try it in windows as well. I
> > use GRASS 6.4.0RC7 with MSYS and referring to Open Source GIS - A GRASS
> > Approach I wanted to display layers using following commands for the
> sample
> > North Carolina dataset -
> > g.region rast=elevation -p
> > d.erase
> > d.rast elevation
> > d.his h=elevation i=elevation_shade and so on...
> > Prior to all these there was d.mon x0 command. It resulted in an
> > error.
> d.mon is the main feature which doesn't work natively in Windows. All
> d.* commands operating by generating an image file (by default, the
> file map.png in the current directory). For screen display, use one of
> the GUIs, or open the map.png file in a viewer which provides a quick
> way to reload the current file.
> Also, note that d.mon has been removed altogether in GRASS 7.
Hello again!
Is displaying on x0 or cairo or png displays using d.mon, the only way to
display layers from command line even in linux? Isn't there a way to type
commands in terminal and get the layers displayed in GRASS GIS Map display
in wxGUI?
Regards,
Chethan S.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100829/273a815c/attachment.html
