[GRASS-user] Displaying layers - GRASS 6.4.0RC7 with MSYS
Glynn Clements
glynn at gclements.plus.com
Sun Aug 29 15:40:36 EDT 2010
Chethan S wrote:
> > d.mon is the main feature which doesn't work natively in Windows. All
> > d.* commands operating by generating an image file (by default, the
> > file map.png in the current directory). For screen display, use one of
> > the GUIs, or open the map.png file in a viewer which provides a quick
> > way to reload the current file.
> > Also, note that d.mon has been removed altogether in GRASS 7.
> Is displaying on x0 or cairo or png displays using d.mon, the only way to
> display layers from command line even in linux? Isn't there a way to type
> commands in terminal and get the layers displayed in GRASS GIS Map display
> in wxGUI?
At present, there isn't a mechanism to "remote control" the GUI from
the command line.
