[GRASS-user] Re: reprojection from Projection Mollweide
Gabriele N. gis.gn at libero.it
Thu Dec 2 15:15:33 EST 2010
I found some other posts .... I'm getting close to the solution (I get good
results):
gdalwarp -s_srs '+proj=goode +ellps=sphere +lon_0=30E +towgs84=0,0,0,0,0,0,0
+x_0=3335846.22854 +y_0=20000' -t_srs '+proj=latlong +ellps=wgs84
towgs84=0,0,0,0,0,0,0' -te 7 33 34 59 map.tif map_wgs84.tif
I do not know why, but that's okay with +proj=good" and not "+proj = moll"
In addition, by removing the parameter y_0 = 20000 I get a more accurate
overlay.
So by the time I reprojected raster in the WGS84 as follows:
gdalwarp -s_srs ' proj=goode  ellps=sphere  lon_0=30E  towgs84=0,0,0,0,0,0,0
x_0=3335846.22854' -t_srs ' proj=latlong  ellps=wgs84 towgs84=0,0,0,0,0,0,0'
Gabriele
View this message in context: http://osgeo-org.1803224.n2.nabble.com/reprojection-from-Projection-Mollweide-tp5797013p5797451.html
Sent from the Grass - Users mailing list archive at Nabble.com.
