[GRASS-user] python module under wingrass7
gianluca.massei
g_massa at libero.it
Mon Dec 13 17:59:50 EST 2010
Hy,
I'm using Grass installer and I've set GISBASE in my system path. I've
tried this procedure without any results:
http://www.mail-archive.com/grass-user@lists.osgeo.org/msg16242.html
Thanks for your help
Il 13/12/2010 23.50, Alex Mandel ha scritto:
> On 12/13/2010 02:28 PM, gianluca.massei wrote:
>> Well, excuse me if I was not clear in previous message. I'll try to
>> give more info:
>> In grass 7 for linux my python module works fine. In wingrass70 I've
>> copied my module in %GISSBASE%/scripts but it doesn't works.
>> I get that message:
>> c:\Progrm Files\GRASS-70-SVN\extralibin\python.exe: can't open file
>> '%GISBASE%/scripts/r.mcda.roughset.py':[Errno 2] No such file or directory'
>> I've read some precedent post but the suggest solutions works for 6.4
>> and in 7.0 I've the same problem.
>> Thanks
>> Il 11/12/2010 20.24, gianluca.massei ha scritto:
>>> I've wrote a simple python module working in grass 7 under linux (It's
>>> only one file). Could anyone help me how can I try it under wingrass
>>> 7? Is not clear for me the install procedure for python module.
>>> thanks in advance.
> Are you sure that GISSBASE is defined in your system paths? Also are you
> using the GRASS installer or the OSGeo4w installer, the OSGeo4w contains
> a shell that ensures all those paths work as they should, not sure about
> the regular GRASS installer.
> What solution did you see for 6.4? Did you try it and did it not work?
> Thanks,
> Alex
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
> Nessun virus nel messaggio.
> Controllato da AVG - www.avg.com
> Versione: 10.0.1170 / Database dei virus: 426/3313 - Data di rilascio: 13/12/2010
