[GRASS-user] Building areas out of contour lines
"Kilian Schönberger"
KiSchoe at gmx.de
Wed Feb 3 05:55:01 EST 2010
Hello,
I have got a SRTM tile and I built the contour lines with r.contour
then I tried e.g. r.surf.contour or to export closed polygons, but I am not confident with the results..
I am looking for a hint to find an efficient way to extract the areas between contour lines which have no boundaries...(?)
perhaps just adding boundaries could be a solution and export closed polygons after this... (?) - closing them by hand takes too much time. Perhaps there is a command to add boundaries to a given region.
thanks..
GRATIS für alle GMX-Mitglieder: Die maxdome Movie-FLAT!
Jetzt freischalten unter http://portal.gmx.net/de/go/maxdome01
