[GRASS-user] Geometric Correction
Markus Neteler
neteler at osgeo.org
Wed Feb 3 14:48:36 EST 2010
On Wed, Feb 3, 2010 at 5:05 PM, Luis Lisboa <luislisboa1975 at gmail.com> wrote:
> While I was reading chapter 8, from Neteler & Mitasova GRASS Book, I
> realized that there is no specific sub-chapter related with Geometric
> Correction. This process is to compensate for the distortions introduced by
> these factors so that the corrected image will have the highest practical
> geometric integrity (Lillesand & Kiefer).
> My question is: How can this be done in GRASS?
The Imagery TODO list is the following:
- merge of image libraries:
A)
- lib/imagery/: standard lib, in use (i.* except for i.points3, i.rectify3)
- imagery/i.ortho.photo/libes/: standard lib, in use
(i.ortho.photo, photo.*)
B)
- lib/image3/: never finished improvement which integrated the
standard lib and
the ortho lib. Seems to provide also ortho rectification for
satellite data (i.points3, i.rectify3)
- image modules:
- merge of i.points, i.vpoints, i.points3
- merge of i.rectify and i.rectify3
- addition of new resampling algorithms such as bilinear, cubic convolution
(take from r.proj?)
- add other warping methods (maybe thin splines from GDAL?)
- implement/finish linewise ortho-rectification of satellite data
- Add support for > 8bit colors (only 0-255 supported currently)
Relevant for you is this:
- "implement/finish linewise ortho-rectification of satellite data"
...unfortunately stuck since GRASS 4/5...
> I suppose it's done since
> LANDSAT-TM need geometric correction and, all GRASS book refers to LANDSAT
> images.
(A part of the book refers to LANDSAT.)
It would be great to see the existing algorithms integrated.
Best
Markus
