[GRASS-user] I.class empty Xmonitor
Luisa Peña
luisapena1979 at gmail.com
Thu Feb 4 07:46:18 EST 2010
Greetings
You need to have "xterm" installed. Please check.
> Perhaps we need to add more error testing in the wxGUI?
I do have installed. I'm running in Ubuntu and with xterm version 243.
Is it required other packages such as xtermcontrol or xtermset? Or more
packages? or in the ./configure to include something?
By the way, I decided to run it not from wxpython but from command line and
I got this:
(Thu Feb 4 12:45:01 2010)
i.class map=lsat7_2002_20 at PERMANENT
group=lsat7_2002 at PERMANENTsubgroup=lsa7_2002 outsig=out
(Thu Feb 4 12:45:01 2010) Command finished (0 sec)
And nothing happened. Am i suppose to open a monitor before or is it suppose
to open by itself?
Thank you
Best regards
Luisa
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100204/8b5dbc29/attachment-0001.html
