[GRASS-user] again Raster names
Glynn Clements
glynn at gclements.plus.com
Fri Feb 5 13:42:23 EST 2010
Niels Thevs wrote:
> in a script, which I executed under GRASS 6.4 under Ubunto, I included
> commands like r.in.gdal input=/media/.../filename output=surfac_ereflection.
> 1. An error message illegal filename <surfac_ereflection.1>, <illegal
> character showed up. When I typed this command into the window underneath
> the output window, it worked fine. I also run the script using data
> on a FAT32 formatted partition as well as data in the /home directory.
> The files to be imported are MODIS data.
How are you creating the script? Are you sure that invalid characters
(e.g. carriage return, non-breaking space, etc) aren't being introduced?
Try to create a minimal script which demonstrates the problem, then
post it as a binary attachment.
