[GRASS-user] Raster Map subset
Milton Cezar Ribeiro
miltinho.astronauta at gmail.com
Fri Feb 5 19:31:52 EST 2010
Hi Stephen,
I suggest you use spgrass6 package on R,
set your g.region using system("g.region n= s= w= e=")
on R and use readRAST6 to load your map
as SGDF. Of course, if you are under windows,
you know that depending the size of your grid
you will get troubles :-)
best
milton
2010/2/5 stephen sefick <ssefick at gmail.com>
> Is there a way to get a subset of a larger raster map. I have zoomed
> into an area and would like to make a raster map only containing that
> area. Can I do this? I am going to use this as input into R for some
> topmodel runs.
> thanks,
> Stephen Sefick
> Let's not spend our time and resources thinking about things that are
> so little or so large that all they really do for us is puff us up and
> make us feel like gods. We are mammals, and have not exhausted the
> annoying little problems of being mammals.
> -K. Mullis
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100205/c2e8d306/attachment.html
