[GRASS-user] Raster Map subset
stephen sefick ssefick at gmail.com
Fri Feb 5 19:33:20 EST 2010
Wonderful- thank you very much.
Stephen
On Fri, Feb 5, 2010 at 6:31 PM, Milton Cezar Ribeiro
<miltinho.astronauta at gmail.com> wrote:
> Hi Stephen,
> I suggest you use spgrass6 package on R,
> set your g.region using system("g.region n= s= w= e=")
> on R and use readRAST6 to load your map
> as SGDF. Of course, if you are under windows,
> you know that depending the size of your grid
> you will get troubles :-)
> best
> milton
> 2010/2/5 stephen sefick <ssefick at gmail.com>
>> Is there a way to get a subset of a larger raster map.  I have zoomed
>> into an area and would like to make a raster map only containing that
>> area.  Can I do this?  I am going to use this as input into R for some
>> topmodel runs.
>> thanks,
>> Stephen Sefick
>> Let's not spend our time and resources thinking about things that are
>> so little or so large that all they really do for us is puff us up and
>> make us feel like gods.  We are mammals, and have not exhausted the
>> annoying little problems of being mammals.
>>        -K. Mullis
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Stephen Sefick
								-K. Mullis
