[GRASS-user] Raster Map subset
Micha Silver
micha at arava.co.il
Sat Feb 6 03:23:28 EST 2010
Rich Shepard wrote:
> On Fri, 5 Feb 2010, stephen sefick wrote:
>> Is there a way to get a subset of a larger raster map. I have zoomed
>> into an area and would like to make a raster map only containing that
>> area. Can I do this? I am going to use this as input into R for some
>> topmodel runs.
> Stephen,
> Yes, you can. This subject has come up several times in the past
> month or
> so so the archives have a lot of options for you. One to look at
> closely is
> v.in.region. After zooming to the area you want, run v.in.region and save
> that vector map. You can then use it with the g.region command to
> limit the
> displayed bounds of your raster map. You can use r.patch to make a new
> raster map that's the size of the newly created vector map.
I'm not sure this is entirely correct. v.in.region saves the current
*computational* region to a vector, not the area zoomed to. Setting the
desired region first with g.region, I think, is the correct way to go.
Then r.mapcalc can create a new raster, limited to the new smaller region.
> Are you aware of r.topmodel within GRASS?
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
Arava Development Co. +972-52-3665918
http://surfaces.co.il
