[GRASS-user] Raster Map subset
MS
mseibel at gmail.com
Sat Feb 6 05:19:51 EST 2010
There is probably a more eloquent way, but I have taken a vector
watershed boundary, converted to a raster, and set as mask. Then used
a r.mapcalc expression like "newMap=oldMap+0".
Mark
On Feb 6, 2010, at 3:23 AM, Micha Silver <micha at arava.co.il> wrote:
> Rich Shepard wrote:
>> On Fri, 5 Feb 2010, stephen sefick wrote:
>>> Is there a way to get a subset of a larger raster map. I have
>>> zoomed
>>> into an area and would like to make a raster map only containing
>>> that
>>> area. Can I do this? I am going to use this as input into R for some
>>> topmodel runs.
>> Stephen,
>> Yes, you can. This subject has come up several times in the past
>> month or
>> so so the archives have a lot of options for you. One to look at
>> closely is
>> v.in.region. After zooming to the area you want, run v.in.region
>> and save
>> that vector map. You can then use it with the g.region command to
>> limit the
>> displayed bounds of your raster map. You can use r.patch to make a
>> new
>> raster map that's the size of the newly created vector map.
> I'm not sure this is entirely correct. v.in.region saves the current
> *computational* region to a vector, not the area zoomed to. Setting
> the desired region first with g.region, I think, is the correct way
> to go. Then r.mapcalc can create a new raster, limited to the new
> smaller region.
>> Are you aware of r.topmodel within GRASS?
>> Rich
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Arava Development Co. +972-52-3665918
> http://surfaces.co.il
