[GRASS-user] I.class empty Xmonitor
Luisa Peña
luisapena1979 at gmail.com
Mon Feb 8 11:55:00 EST 2010
how do you start GRASS? by clicking on an icon or menu item, or with
> "grass64" typed at the command line in a terminal?
By typing "grass64 -wxpython" in my terminal.
> please try starting from the command line, and then also from the GRASS>
> prompt running 'd.mon x0' and i.class. --not from the GUI--.
> The interactive menus should be in text in the terminal, not in the
> Xmonitor.
After d.on x0 it printed
using default visual which is TrueColor
ncolors: 16777216
Graphics driver [x0] started
Ok it asks for input raster map, group, sub-group and output file and
existing files.
Then, it opens 2 monitors:
- 1 to visualize image (zoomed, signatures etc)
- other divided in two stating "use mouse now"
I suppose this is what it's suppose to be expecting from i.class module
right?
(I tried to save a file but it saved only # ==> But for now I just want to
fix this, before understanding what am I doing wrong regarding i.class use)
How can I do this inside a wxpython? :)
?? where does the x-terminal-emulator symlink in /etc/alternatives/
> point to ?
The file x-terminal-emulation at etc/alternatives is not a link but an
executable file.
doing nm x-terminal emulator I get:
nm: x-terminal-emulator: File format not recognized
x-terminal-emulator has the following code:
#! /usr/bin/perl -w
my $login=0;
while ($opt = shift(@ARGV))
if ($opt eq '-display')
$ENV{'DISPLAY'} = shift(@ARGV);
elsif ($opt eq '-name')
$arg = shift(@ARGV);
push(@args, "--window-with-profile=$arg");
elsif ($opt eq '-n')
# Accept but ignore
print STDERR "$0: to set an icon, please use -name <profile> and set a
profile icon\n"
elsif ($opt eq '-T' || $opt eq '-title')
push(@args, '-t', shift(@ARGV));
elsif ($opt eq '-ls')
$login = 1;
elsif ($opt eq '+ls')
$login = 0;
elsif ($opt eq '-geometry')
push(@args, "--geometry=$arg");
elsif ($opt eq '-fn')
push(@args, "--font=$arg");
elsif ($opt eq '-fg')
push(@args, "--foreground=$arg");
elsif ($opt eq '-bg')
push(@args, "--background=$arg");
elsif ($opt eq '-tn')
push(@args, "--termname=$arg");
elsif ($opt eq '-e')
if (@ARGV)
push(@args, '-x', $arg, @ARGV);
last;
else
push(@args, '-e', $arg);
last;
elsif ($opt eq '-h' || $opt eq '--help')
push(@args, '--help');
if ($login == 1)
@args = ('--login', @args);
exec('gnome-terminal', at args);
Does this help???
Thank you Hamish for all your help
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100208/19dffa8c/attachment-0001.html
