[GRASS-user] Re: Defining Partial Drainage Basin
Micha Silver micha at arava.co.il
Wed Feb 10 02:22:15 EST 2010
On 02/10/2010 12:32 AM, Rich Shepard wrote:
> On Tue, 9 Feb 2010, Rich Shepard wrote:
>> I want to limit my analyses to that portion of the basin that drains
>> into
>> a specified location along the main creek. Which module will allow me to
>> define a partial basin with this point as the outlet?
> Got it. r.water.outlet, after running r.watershed.
A quick tip regarding r.water.outlet (you may have noticed this already)
The module creates a new raster covering the whole analysis region with
two possible values: 1 for all cells draining into the outlet, and 0
everywhere else. If you do r.to.vect straightaway, youĺl get a vector
containing two polygons...
I always run r.null setnull=0 on the r.water.outlet result first. This
insures that r.to.vect leaves you with just the drainage area.
> BTW. is there a readily available source for learning how to interpret
> the
> output maps of these various terrain/hydrological modules?
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
Micha Silver
http://www.surfaces.co.il/
Arava Development Co.  +972-52-3665918
