[GRASS-user] Re: Defining Partial Drainage Basin
Rich Shepard
rshepard at appl-ecosys.com
Wed Feb 10 13:22:14 EST 2010
On Wed, 10 Feb 2010, Micha Silver wrote:
> A quick tip regarding r.water.outlet (you may have noticed this already)
> The module creates a new raster covering the whole analysis region with
> two possible values: 1 for all cells draining into the outlet, and 0
> everywhere else. If you do r.to.vect straightaway, you?l get a vector
> containing two polygons... I always run r.null setnull=0 on the
> r.water.outlet result first. This insures that r.to.vect leaves you with
> just the drainage area.
Micha,
I'm under a deadline to finish the current project, and nothing seems to
be working correctly for me.
I just ran r.water.outlet using the drainage (aspect) map created by
r.watershed. The output is a yellow rectangle that the legend tells me
represents '0'; that is, there're no cells in the calculated basin.
g.region -p reports:
projection: 99 (Lambert Conformal Conic)
zone: 0
datum: nad83
ellipsoid: grs80
north: 1334420
south: 1279150
west: 769190
east: 819260
nsres: 10
ewres: 10
rows: 5527
cols: 5007
cells: 27673689
The command line was:
r.water.outlet drain=aber10m.drain basin=lockie e=795542.95 n=1308323.52 --o
I can send copies of aber10m.drain and lockie. It makes no sense to me
that such a simple run fails to define the partial drainage basin. Any help
or ideas you offer will be much appreciated.
Rich
