[GRASS-user] d.vect without centroid icon
    Daniel Victoria
    daniel.victoria at gmail.com
    Wed Feb 10 20:07:18 EST 2010
If you are displaying using command line, d.vect manual tells us about
options display and type. Not sure which to use but I believe one
should do what you want.
If you are using the GUI, the vector properties will let you turn of
centroids and do other cool stuff.
On Wed, Feb 10, 2010 at 10:27 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
>  When I overlay a raster map with the vector watershed boundaries the
> centroid of that vector map is displayed as a small 'x.' Is there a way to
> remove that centroid from the display?
> Thanks,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
