[GRASS-user] Two General Questions
Glynn Clements
glynn at gclements.plus.com
Fri Feb 12 20:35:02 EST 2010
Jarek Jasiewicz wrote:
> >> nviz give you really impressive visuals with maximum resolution ppm
> >> images
> >> (require posterior GIMP post processing) but please! read manual first.
> maximum resolution ppm will give you tiled image which must be joined
Normally, NVIZ joins the tiles into a single large image (with pnmcat)
then deletes the tiles. But if the pnmcat command fails (e.g. because
pnmcat isn't installed), it doesn't delete the tiles, leaving the user
the option of joining them by some other means.
pnmcat is in the NetPBM package.
