[GRASS-user] Two General Questions
    Jarek Jasiewicz
    jarekj at amu.edu.pl
    Sat Feb 13 03:46:36 EST 2010
Glynn Clements pisze:
> Jarek Jasiewicz wrote:
>>>> nviz give you really impressive visuals with maximum resolution ppm
>>>> images
>>>> (require posterior GIMP post processing) but please! read manual first.
>> maximum resolution ppm will give you tiled image which must be joined
> Normally, NVIZ joins the tiles into a single large image (with pnmcat)
> then deletes the tiles. But if the pnmcat command fails (e.g. because
> pnmcat isn't installed), it doesn't delete the tiles, leaving the user
> the option of joining them by some other means.
> pnmcat is in the NetPBM package.
thanks Glynn!
J.
