[GRASS-user] r.flow Terminates With Error
Markus Neteler
neteler at osgeo.org
Sat Feb 13 11:12:47 EST 2010
On Fri, Feb 12, 2010 at 9:22 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Fri, 12 Feb 2010, Rich Shepard wrote:
>> I had no problems running r.flow with in the input elevation map
>> resolution
>> of 5m x 5m. However, now it won't run (even with the -m switch) on a DEM
>> with 3m x 3m resolution:
> Must be a memory issue (with 2G installed and top reporting Mem: 2041212k
> total, 1989652k used, 51560k free, 40576k buffers)
> Anyway, it's running when I specify one output map at a time. Flow lengths
> are being calculated now and consuming 95% of the CPU and 70% of memory,
> with disk swapping turned on for the module.
Did you compile with LFS (large file support) enabled?
Markus
