[GRASS-user] Re: How to join 3D object to database
Gazz1982 garynobles at yahoo.com
Sun Feb 14 17:36:26 EST 2010
Hi Stefania,
You could import the csv file into MySQL database and then use the
v.db.connect modules . I'm not sure if it would work for your data, does
GRASS treat the faces as conventional vectors?
Good luck
Gary Nobles
View this message in context: http://n2.nabble.com/How-to-join-3D-object-to-database-tp4571552p4571967.html
Sent from the Grass - Users mailing list archive at Nabble.com.
