[GRASS-user] d.rast doesn't display on monitor
Markus Neteler
neteler at osgeo.org
Tue Feb 16 09:04:41 EST 2010
On Thu, Feb 11, 2010 at 6:55 AM, sidtupper <sid at sidtupper.ca> wrote:
> I'm expecting that the following commands in GIS.m should display a
> spearfish60 map on monitor x0:
> g.region rast=elevation.10m at PERMANENT
> d.mon x0
> d.rast elevation.10m at PERMANENT
yes, this should display the map in the GRASS monitor (not the gis.m
output which is controlled by the gis.m display manager).
> They run without error but nothing appears on the monitor. I can display
> the map on Map Display 1, though. I'm using GRASS 6.3.0 with a 2.6.31
> Gentoo kernel.
> What am I doing wrong / missing? Thanks ...
It is not clear to me what you are missing.
To see maps in the monitor controlled by gis.m, use the layer manager.
To see maps in the x0 monitor, use the d.* commands.
Markus
> View this message in context: http://n2.nabble.com/d-rast-doesn-t-display-on-monitor-tp4552956p4552956.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
