[GRASS-user] d.rast doesn't display on monitor
sidtupper sid at sidtupper.ca
Thu Feb 11 00:55:28 EST 2010
I'm expecting that the following commands in GIS.m should display a
spearfish60 map on monitor x0:
g.region rast=elevation.10m at PERMANENT
d.mon x0
d.rast elevation.10m at PERMANENT
They run without error but nothing appears on the monitor.  I can display
the map on Map Display 1, though.  I'm using GRASS 6.3.0 with a 2.6.31
Gentoo kernel.
What am I doing wrong / missing?   Thanks ...
View this message in context: http://n2.nabble.com/d-rast-doesn-t-display-on-monitor-tp4552956p4552956.html
Sent from the Grass - Users mailing list archive at Nabble.com.
