Fwd: [GRASS-user] I.class empty Xmonitor
Luisa Peña
luisapena1979 at gmail.com
Wed Feb 17 06:57:09 EST 2010
Good Morning
try:
> ls -l /etc/alternatives/x-terminal-emulator
> and what is on the right side of the ->
The result is:
/usr/bin/gnome-terminal.wrapper
Does this help in any way to understand why I can't launch from Wxpython?
> yes, so it is now working?
Well it's working as a command line not in wxPython GUI.
> Until someone rewrites it, you have to use the old terminal +
> d.mon interface.
But is it possible, from a wxpython menu to launch a process like that one?
> so, are you still stuck? at "saved only #"?
Welll, Yes but maybe I'm just a newbie in using this module. Probably I will
contact the developers to understand this better.
Another question that might help on this. Which include are necessary to use
i.class, i.ortho.photos I mean the modules that requires Xterm? Maybe I have
missed on include
THank you Hamish for all your help
Luisa
S.Paulo, Brazil
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100217/37a0be41/attachment.html
