Fwd: [GRASS-user] I.class empty Xmonitor
Luisa Peña
luisapena1979 at gmail.com
Wed Feb 17 09:21:01 EST 2010
Regarding i.class use, thanks Hamish :) I will try that
But regarding launching i.class from wxpython. In 6.4 is not working. Is it
suppose to work? Maybe it has something to do with some include that is
required for Xterm. Any thoughts? Because it's not practical to use d.mon X0
bla bla bla
Thanks
2010/2/17 Hamish <hamish_b at yahoo.com>
> Luisa Peña wrote:
> > Well it's working as a command line not in wxPython GUI.
> > But is it possible, from a wxpython
> > menu to launch a process like that one?
> it works for me from the wxGUI in 6.5.. shrug
> > > so, are you still stuck? at "saved only #"?
> > Welll, Yes but maybe I'm just a
> > newbie in using this module.
> I don't know these modules at all but I could get it to write a
> little more to the $MAPSET/groups/$GROUPNAME/$SUBGROUP/sig/$sigfile
> with :
> i.class ...
> zoom
> define region
> click click click
> complete region
> done
> analyse region
> display matches
> set std dev's
> display matches
> done
> save? [yes]
> type in a description of the blob you made in the xterm
> redisplay map
> map window
> .. create another region in you want
> quit [yes]
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100217/3e4753a4/attachment.html
