[GRASS-user] HDF-5 parse
Pedro Roma
pedroroma1982 at gmail.com
Wed Feb 17 11:09:30 EST 2010
Hello all
Regarding this question, I’m using a MSG SEVIRI product called FAPAR. And
I’m a bit lost on import data to GRASS and rectify.
By making gldainfo I get:
Driver: HDF5/Hierarchical Data Format Release 5
Files: /mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000
Size is 512, 512
Coordinate System is `'
Subdatasets:
SUBDATASET_1_NAME=HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR
SUBDATASET_1_DESC=[651x1701] //FAPAR (8-bit integer)
SUBDATASET_2_NAME=HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR_QF
SUBDATASET_2_DESC=[651x1701] //FAPAR_QF (8-bit character)
SUBDATASET_3_NAME=HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR_err
SUBDATASET_3_DESC=[651x1701] //FAPAR_err (8-bit integer)
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 512.0)
Upper Right ( 512.0, 0.0)
Lower Right ( 512.0, 512.0)
Center ( 256.0, 256.0)
I get a list of all subsets. Apparentely there is no coordinate system
right?
But if I make
gdalinfo HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR
(one of the SUBSETS) I get:
Driver: HDF5Image/HDF5 Dataset
Files: none associated
Size is 1701, 651
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AXIS["Lat",NORTH],
AXIS["Long",EAST],
AUTHORITY["EPSG","4326"]]
Corner Coordinates:
Lower Left ( 0.0, 651.0)
Upper Right ( 1701.0, 0.0)
Lower Right ( 1701.0, 651.0)
Center ( 850.5, 325.5)
Band 1 Block=1701x1 Type=Int16, ColorInterp=Undefined
Metadata:
FAPAR:CLASS=Data
FAPAR:PRODUCT=product
FAPAR:PRODUCT_ID=0
FAPAR:N_COLS=1701
FAPAR:N_LINES=651
FAPAR:NB_BYTES=2
FAPAR:SCALING_FACTOR=10000
FAPAR:OFFSET=0
FAPAR:MISSING_VALUE=-10
FAPAR:UNITS=N/A
FAPAR:CAL_SLOPE=1
FAPAR:CAL_OFFSET=0
This means that it’s georreferenced right?
But if I do
r.in.gdal -o --quiet input=HDF5:"/mnt/GIS/ DATA
/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR output=out00
I get the error:
Over-riding projection check
G_set_window(): Illegal latitude for NorthOver-riding projection check
So it doesn’t’ work. I mean shouldn’t I be using gdalwarp in order to import
and rectify image? Because there is not much inofmration regarding how to do
this. I mean, it seems that if I do r.in.gdal I loose all GCP and
coordinates system information...
Sorry for these lammer questions but I think I'm lost
Thanks
Pedro
2010/2/17 Pedro Roma <pedroroma1982 at gmail.com>
> Thank you all.
> Regarding Antonio's suggestion I will see if I can do that. It seems a good
> Idea. Is it possible to have a button to browse files?
> Thanks
> Best regards
> Pedro
> 2010/2/17 António Rocha <antonio.rocha at deimos.com.pt>
> Hello Pedro
>> My suggestion, in case you have a consistent dataset, would be to create
>> your own script to read import HDF5 files. My question regarding this is it
>> possible to have a "Browse files" button in a GRASS scripts?
>> Antonio
>> __________ Information from ESET NOD32 Antivirus, version of virus
>> signature database 4872 (20100216) __________
>> The message was checked by ESET NOD32 Antivirus.
>> http://www.eset.com
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100217/b9ec5549/attachment.html
