[GRASS-user] HDF-5 parse
Markus Neteler
neteler at osgeo.org
Wed Feb 17 12:11:58 EST 2010
2010/2/17 Pedro Roma <pedroroma1982 at gmail.com>:
> Hello all
> Regarding this question, I’m using a MSG SEVIRI product called FAPAR. And
> I’m a bit lost on import data to GRASS and rectify.
> By making gldainfo I get:
> Driver: HDF5/Hierarchical Data Format Release 5
> Files: /mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000
> Size is 512, 512
> Coordinate System is `'
> Subdatasets:
> SUBDATASET_1_NAME=HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR
> SUBDATASET_1_DESC=[651x1701] //FAPAR (8-bit integer)
> SUBDATASET_2_NAME=HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR_QF
> SUBDATASET_2_DESC=[651x1701] //FAPAR_QF (8-bit character)
> SUBDATASET_3_NAME=HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR_err
> SUBDATASET_3_DESC=[651x1701] //FAPAR_err (8-bit integer)
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 512.0)
> Upper Right ( 512.0, 0.0)
> Lower Right ( 512.0, 512.0)
> Center ( 256.0, 256.0)
> I get a list of all subsets. Apparentely there is no coordinate system
> right?
> But if I make
> gdalinfo HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR
> (one of the SUBSETS) I get:
> Driver: HDF5Image/HDF5 Dataset
> Files: none associated
> Size is 1701, 651
> Coordinate System is:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9108"]],
> AXIS["Lat",NORTH],
> AXIS["Long",EAST],
> AUTHORITY["EPSG","4326"]]
> Corner Coordinates:
> Lower Left ( 0.0, 651.0)
> Upper Right ( 1701.0, 0.0)
> Lower Right ( 1701.0, 651.0)
> Center ( 850.5, 325.5)
> Band 1 Block=1701x1 Type=Int16, ColorInterp=Undefined
> Metadata:
> FAPAR:CLASS=Data
> FAPAR:PRODUCT=product
> FAPAR:PRODUCT_ID=0
> FAPAR:N_COLS=1701
> FAPAR:N_LINES=651
> FAPAR:NB_BYTES=2
> FAPAR:SCALING_FACTOR=10000
> FAPAR:OFFSET=0
> FAPAR:MISSING_VALUE=-10
> FAPAR:UNITS=N/A
> FAPAR:CAL_SLOPE=1
> FAPAR:CAL_OFFSET=0
> This means that it’s georreferenced right?
Not necessarily. It is also possible that GCPs are stored and gdalwarp
needs to be
used first to obtain a really geocoded file.
> But if I do
> r.in.gdal -o --quiet input=HDF5:"/mnt/GIS/ DATA
> /HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR output=out00
> I get the error:
> Over-riding projection check
> G_set_window(): Illegal latitude for NorthOver-riding projection check
> So it doesn’t’ work. I mean shouldn’t I be using gdalwarp in order to import
> and rectify image?
Say, use gdalwarp to preprocess the data. Please try with one channel and
post what gdalinfo reports on the resulting file.
Markus
> Because there is not much inofmration regarding how to do
> this. I mean, it seems that if I do r.in.gdal I loose all GCP and
> coordinates system information...
> Sorry for these lammer questions but I think I'm lost
> Thanks
> Pedro
>> Thank you all.
>> Regarding Antonio's suggestion I will see if I can do that. It seems a
>> good Idea. Is it possible to have a button to browse files?
>> Thanks
>> Best regards
>> Pedro
>> 2010/2/17 António Rocha <antonio.rocha at deimos.com.pt>
>>> Hello Pedro
>>> My suggestion, in case you have a consistent dataset, would be to create
>>> your own script to read import HDF5 files. My question regarding this is it
>>> possible to have a "Browse files" button in a GRASS scripts?
>>> Antonio
>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>> signature database 4872 (20100216) __________
>>> The message was checked by ESET NOD32 Antivirus.
>>> http://www.eset.com
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
