[GRASS-user] HDF-5 parse
António Rocha
antonio.rocha at deimos.com.pt
Wed Feb 17 12:21:02 EST 2010
Pedro, regarding MODIS tip, that someone gave you, please try Method 1
and see what happens. I think it will be enough. Please pay attention to
HDF5 instead of HDF4.
Antonio
Markus Neteler wrote:
> 2010/2/17 Pedro Roma <pedroroma1982 at gmail.com>:
>> Hello all
>> Regarding this question, I’m using a MSG SEVIRI product called FAPAR. And
>> I’m a bit lost on import data to GRASS and rectify.
>> By making gldainfo I get:
>> Driver: HDF5/Hierarchical Data Format Release 5
>> Files: /mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000
>> Size is 512, 512
>> Coordinate System is `'
>> Subdatasets:
>> SUBDATASET_1_NAME=HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR
>> SUBDATASET_1_DESC=[651x1701] //FAPAR (8-bit integer)
>> SUBDATASET_2_NAME=HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR_QF
>> SUBDATASET_2_DESC=[651x1701] //FAPAR_QF (8-bit character)
>> SUBDATASET_3_NAME=HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR_err
>> SUBDATASET_3_DESC=[651x1701] //FAPAR_err (8-bit integer)
>> Corner Coordinates:
>> Upper Left ( 0.0, 0.0)
>> Lower Left ( 0.0, 512.0)
>> Upper Right ( 512.0, 0.0)
>> Lower Right ( 512.0, 512.0)
>> Center ( 256.0, 256.0)
>> I get a list of all subsets. Apparentely there is no coordinate system
>> right?
>> But if I make
>> gdalinfo HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR
>> (one of the SUBSETS) I get:
>> Driver: HDF5Image/HDF5 Dataset
>> Files: none associated
>> Size is 1701, 651
>> Coordinate System is:
>> GEOGCS["WGS 84",
>> DATUM["WGS_1984",
>> SPHEROID["WGS 84",6378137,298.257223563,
>> AUTHORITY["EPSG","7030"]],
>> TOWGS84[0,0,0,0,0,0,0],
>> AUTHORITY["EPSG","6326"]],
>> PRIMEM["Greenwich",0,
>> AUTHORITY["EPSG","8901"]],
>> UNIT["degree",0.0174532925199433,
>> AUTHORITY["EPSG","9108"]],
>> AXIS["Lat",NORTH],
>> AXIS["Long",EAST],
>> AUTHORITY["EPSG","4326"]]
>> Corner Coordinates:
>> Lower Left ( 0.0, 651.0)
>> Upper Right ( 1701.0, 0.0)
>> Lower Right ( 1701.0, 651.0)
>> Center ( 850.5, 325.5)
>> Band 1 Block=1701x1 Type=Int16, ColorInterp=Undefined
>> Metadata:
>> FAPAR:CLASS=Data
>> FAPAR:PRODUCT=product
>> FAPAR:PRODUCT_ID=0
>> FAPAR:N_COLS=1701
>> FAPAR:N_LINES=651
>> FAPAR:NB_BYTES=2
>> FAPAR:SCALING_FACTOR=10000
>> FAPAR:OFFSET=0
>> FAPAR:MISSING_VALUE=-10
>> FAPAR:UNITS=N/A
>> FAPAR:CAL_SLOPE=1
>> FAPAR:CAL_OFFSET=0
>> This means that it’s georreferenced right?
> Not necessarily. It is also possible that GCPs are stored and gdalwarp
> needs to be
> used first to obtain a really geocoded file.
>> But if I do
>> r.in.gdal -o --quiet input=HDF5:"/mnt/GIS/ DATA
>> /HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR output=out00
>> I get the error:
>> Over-riding projection check
>> G_set_window(): Illegal latitude for NorthOver-riding projection check
>> So it doesn’t’ work. I mean shouldn’t I be using gdalwarp in order to import
>> and rectify image?
> Say, use gdalwarp to preprocess the data. Please try with one channel and
> post what gdalinfo reports on the resulting file.
> Markus
>> Because there is not much inofmration regarding how to do
>> this. I mean, it seems that if I do r.in.gdal I loose all GCP and
>> coordinates system information...
>> Sorry for these lammer questions but I think I'm lost
>> Thanks
>> Pedro
>>> Thank you all.
>>> Regarding Antonio's suggestion I will see if I can do that. It seems a
>>> good Idea. Is it possible to have a button to browse files?
>>> Thanks
>>> Best regards
>>> Pedro
>>> 2010/2/17 António Rocha <antonio.rocha at deimos.com.pt>
>>>> Hello Pedro
>>>> My suggestion, in case you have a consistent dataset, would be to create
>>>> your own script to read import HDF5 files. My question regarding this is it
>>>> possible to have a "Browse files" button in a GRASS scripts?
>>>> Antonio
>>>> __________ Information from ESET NOD32 Antivirus, version of virus
>>>> signature database 4872 (20100216) __________
>>>> The message was checked by ESET NOD32 Antivirus.
>>>> http://www.eset.com
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> __________ Information from ESET NOD32 Antivirus, version of virus signature database 4874 (20100217) __________
> http://www.eset.com
http://www.eset.com
