[GRASS-user] HDF-5 parse
Pedro Roma
pedroroma1982 at gmail.com
Wed Feb 17 12:36:42 EST 2010
Hey
> Not necessarily. It is also possible that GCPs are stored and gdalwarp
> needs to be
> used first to obtain a really geocoded file.
> Say, use gdalwarp to preprocess the data. Please try with one channel and
> post what gdalinfo reports on the resulting file.
Since GRASS documentation extensively preprocess to GEOTIFF, I will try
that. Is it the best thing to do?
ok here it goes
By using
gdalinfo HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR
I get:
Driver: HDF5Image/HDF5 Dataset
Files: none associated
Size is 1701, 651
Coordinate System is:
GEOGCS["WGS 84",
DATUM["WGS_1984",
SPHEROID["WGS 84",6378137,298.257223563,
AUTHORITY["EPSG","7030"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6326"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9108"]],
AXIS["Lat",NORTH],
AXIS["Long",EAST],
AUTHORITY["EPSG","4326"]]
Corner Coordinates:
Upper Left ( 0.0, 0.0)
Lower Left ( 0.0, 651.0)
Upper Right ( 1701.0, 0.0)
Lower Right ( 1701.0, 651.0)
Center ( 850.5, 325.5)
Band 1 Block=1701x1 Type=Int16, ColorInterp=Undefined
Metadata:
FAPAR:CLASS=Data
FAPAR:PRODUCT=product
FAPAR:PRODUCT_ID=0
FAPAR:N_COLS=1701
FAPAR:N_LINES=651
FAPAR:NB_BYTES=2
FAPAR:SCALING_FACTOR=10000
FAPAR:OFFSET=0
FAPAR:MISSING_VALUE=-10
FAPAR:UNITS=N/A
FAPAR:CAL_SLOPE=1
FAPAR:CAL_OFFSET=0
If I do :
gdalwarp
HDF5:"/mnt/GIS/LSASAF/HDF5_LSASAF_MSG_FAPAR_Euro_200702220000"://FAPAR
/mnt/GIS/testing.tif
I get:
ERROR 1: Unable to compute a transformation between pixel/line
and georeferenced coordinates for
HDF5:/mnt/GIS/LSASAF/HDF5_LSASAF_MSG_FAPAR_Euro_200702220000://FAPAR.
There is no affine transformation and no GCPs.
Is this helpful to solve this question?
At MODIS Wiki (http://grass.osgeo.org/wiki/MODIS) Gdal Warp is not used.
Instead, it's create a intermediate file (TIF) using gdal_translate and only
then is r.in.gdal is used.
Thank you Markus and Antonio and Hamish for your help
> Markus
> > Because there is not much inofmration regarding how to do
> > this. I mean, it seems that if I do r.in.gdal I loose all GCP and
> > coordinates system information...
> > Sorry for these lammer questions but I think I'm lost
> > Thanks
> > Pedro
> > 2010/2/17 Pedro Roma <pedroroma1982 at gmail.com>
> >> Thank you all.
> >> Regarding Antonio's suggestion I will see if I can do that. It seems a
> >> good Idea. Is it possible to have a button to browse files?
> >> Thanks
> >> Best regards
> >> Pedro
> >> 2010/2/17 António Rocha <antonio.rocha at deimos.com.pt>
> >>> Hello Pedro
> >>> My suggestion, in case you have a consistent dataset, would be to
> create
> >>> your own script to read import HDF5 files. My question regarding this
> is it
> >>> possible to have a "Browse files" button in a GRASS scripts?
> >>> Antonio
> >>> __________ Information from ESET NOD32 Antivirus, version of virus
> >>> signature database 4872 (20100216) __________
> >>> The message was checked by ESET NOD32 Antivirus.
> >>> http://www.eset.com
> > grass-user mailing list
> > grass-user at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100217/286e9ca9/attachment-0001.html
