[GRASS-user] HDF-5 parse
Hamish
hamish_b at yahoo.com
Thu Feb 18 07:17:47 EST 2010
Pedro Roma wrote:
> By usinggdalinfo
> HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR
> I get:Driver:
> HDF5Image/HDF5 Dataset
> Files: none associatedSize is 1701,
> 651Coordinate System
> is:GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9108"]],
> AXIS["Lat",NORTH],
> AXIS["Long",EAST],
> AUTHORITY["EPSG","4326"]]Corner
> Coordinates:Upper Left ( 0.0,
> 0.0)Lower Left ( 0.0,
> 651.0)Upper Right ( 1701.0, 0.0)
> Lower Right ( 1701.0, 651.0)Center
> ( 850.5, 325.5)Band 1 Block=1701x1
> Type=Int16,
> ColorInterp=Undefined Metadata:
> FAPAR:CLASS=Data
> FAPAR:PRODUCT=product
> FAPAR:PRODUCT_ID=0
> FAPAR:N_COLS=1701
> FAPAR:N_LINES=651
> FAPAR:NB_BYTES=2
> FAPAR:SCALING_FACTOR=10000
> FAPAR:OFFSET=0
> FAPAR:MISSING_VALUE=-10
> FAPAR:UNITS=N/A
> FAPAR:CAL_SLOPE=1
> FAPAR:CAL_OFFSET=0
> If I do :gdalwarp
> HDF5:"/mnt/GIS/LSASAF/HDF5_LSASAF_MSG_FAPAR_Euro_200702220000"://FAPAR
> /mnt/GIS/testing.tif
> I get:ERROR 1: Unable to compute a
> transformation between pixel/lineand
> georeferenced coordinates for
> HDF5:/mnt/GIS/LSASAF/HDF5_LSASAF_MSG_FAPAR_Euro_200702220000://FAPAR.
> There is no affine transformation and no GCPs.
the above tells you that it is in lat/lon WGS84, but the image itself
is not georeferenced.
are there possibly additional data bands named "lat" and "long" or so?
do you know what the north/south/east/west & resolution should be?
maybe there is another HDF5 viewer (ISTR a java one from NASA?) which
will export the info if it is a gdal or libhdf problem which is stopping
you from seeing that information (if it is there at all)
> Is this helpful to solve this
> question?At MODIS Wiki (http://grass.osgeo.org/wiki/MODIS)
> Gdal Warp is not used. Instead, it's create a
> intermediate file (TIF) using gdal_translate and only then
> is r.in.gdal is used.
gdalwarp is used if there is no north/south/east/west info beyond the
number of image pixels, but there are a series of GCPs listed.
Hamish
