[GRASS-user] SVN Branches
Markus Neteler neteler at osgeo.org
Wed Feb 17 12:16:10 EST 2010
On Wed, Feb 17, 2010 at 4:55 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> On Wed, 17 Feb 2010, Markus Neteler wrote:
>> We have
>> - 6.4.release-branch from which RC5 was extracted some months ago
>>  -> weekly source code and Linux binary snapshots are generated
>>  -> daily winGRASS binaries are generated
> Markus,
>  Do I interpret the above that you extracted RC5 from the stable release?
>  Here's the URL: <http://trac.osgeo.org/grass/wiki/DownloadSource#GRASS6.4>
> and this is what I see:
> GRASS 6.4
> To extract the current 6.4.0 release candidate 5 (RC5) use the command:
>  svn checkout
> https://svn.osgeo.org/grass/grass/tags/release_20090609_grass_6_4_0RC5
> grass640_rc5
> To extract the current 6.4.x release branch version (stable) use the
> command:
>  svn checkout https://svn.osgeo.org/grass/grass/branches/releasebranch_6_4
> grass64_release
Now I understand your confusion.
I have inverted the order and changed the wording to
GRASS 6.4
To extract the current state of the 6.4.x release branch version
(stable), use the command:
grass64_release
To extract the 6.4.0 release candidate 5 (RC5) from 2009, use the command:
  svn checkout https://svn.osgeo.org/grass/grass/tags/release_20090609_grass_6_4_0RC5
grass640_rc5
Does it make more sense now?
>  Are you developing both the stable and release candidate versions
> simultaneously? Do both have identical code? If I want the patch you added
> late last week which branch do I use?
then use "the current state of the 6.4.x release branch" (so the upper after the
modification).
You can simply stay on that branch and update with
svn up
from time to time to fetch latest fixes. I am using that for my production
systems.
Markus
