[GRASS-user] Selecting Vector Map Segments Within GUI
Rich Shepard
rshepard at appl-ecosys.com
Thu Feb 18 10:08:27 EST 2010
On Wed, 17 Feb 2010, Hamish wrote:
> - try updating svn to r41074
Hamish,
I downloaded and built whatever was available yesterday. Don't know the
build number.
> - tcltk module GUI: it seems to be hit or miss when the output buffer
> will be flushed and you get to see the node+distance output. Maybe
> it saves it all up until you exit.
I was using wxPython widgets and GUI.
> - wx module GUI: no module output makes it to the Output tab of the module,
> but if you know that left mouse button = set starting point; middle =
> set end point, and right click = quit, the graphical part seems to work.
I didn't know this until I ran the d.path module in the console monitor.
Thanks,
Rich
