[GRASS-user] graphically selecting multiple features
Vincent Bain
bain at toraval.fr
Fri Feb 19 02:21:10 EST 2010
Hello Kurt,
may it help you, I wrote a /very draft/ add-on that could help you :
http://grass.osgeo.org/wiki/GRASS_AddOns#v.selmany
The name of the module should remind you of old AI stuff... it's a shell
script, so not working with grass70, and only tested with postgresql
database connection (it will probably fail with dbf driver). Grass has
to be launched in text mode (type "grass64 -text" from your shell
prompt), and there must be an open monitor (d.mon).
Good luck !
Vincent.
Le jeudi 18 février 2010 à 16:53 -0700, Kurtis Blaikie-Birkigt a écrit :
> Hello, I'm new to GRASS, coming from an Arc* background, and often find
> that I'm approaching things from the wrong direction. I'm using GRASS
> 6.4 with the wxPython GUI.
> I would like to graphically select multiple features from a large vector
> file and edit an attribute of those features. (I have a poorly
> classified polygon shapefile of hydrology and want to separate the
> rivers from the lakes). How can I go about this. With v.what.vect I
> seem to be able to only edit one feature at a time.
> Any suggestions will be appreciated.
> Thanks,
> Kurt
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
