[GRASS-user] Projection Units and Values Negatively Affect
r.topidx Results
Markus Neteler
neteler at osgeo.org
Sat Feb 20 04:39:32 EST 2010
On Sat, Feb 20, 2010 at 2:12 AM, Hamish <hamish_b at yahoo.com> wrote:
> Rich:
>> Wow! After all of yesterday's anguish, 6.5's r.proj
>> did the trick. That's teriffic! So, should I continue this
>> project in 6.5 or revert to the 6.4 revision 41119?
> the modules are the same, the only difference is the new -p
> and -g flags in 6.5 which can save you some time by not needing
> to use the v.in.region where-am-I trick.
Please let's backport it for 6.4.1 then.
Markus
