[GRASS-user] WxGUI issues: refresh and labels
Micha Silver
micha at arava.co.il
Sat Feb 20 05:16:21 EST 2010
Richard Chirgwin wrote:
> Thanks everybody, I will just send one response!
> First - Micha, thank you! I didn't even know there was another box to
> check.
I'd like to raise the question (again) regarding displaying vector
labels in wxGUI and the need to check the "attr" checkbox in the
"Optional" tab.
The d.vect command requires specifying both the attrcol=xxx and the
display=shape,attr parameters. In parallel to that, the wxGUI window for
displaying a vector requires in the "Labels" tab to select the labels
column, *and* in the "Optional" tab to check the attr checkbox.
While I appreciate the need to keep the GUI in line with the
command-line options, the above GUI arrangement is just not intuitive.
I'm sure Richard won't be the last user to get caught by this.
Is it not possible to add the display=attr checkbox to the "Labels" tab,
so that you do all labeling actions - enable labeling, choose the column
along with label fonts, colors etc - in the *same* place?? Perhaps even
leave the "Name of column", "Label color", etc all greyed out unless the
Enable labeling (i.e disp=attr) is checked...
Thanks,
Micha
