[GRASS-user] stable java library for grass
"Sören Gebbert"
soerengebbert at gmx.de
Sun Feb 21 08:44:20 EST 2010
Hello,
i am not sure, but maybe this will help you a bit?
There is the vtkGRASSBrige:
http://code.google.com/p/vtk-grass-bridge/
vtkGRASSBridge provides a VTK/C++ interface to most of the grass gis raster and vector C library functions. Its using an intuitive class structure to hide the complexity of the grass libraries.
Additionally, the vtkGRASSBridge provides access to grass C library functions for Python and Java, using the VTK wrapper.
This little software project also provides a simple framework to start grass modules:
http://code.google.com/p/vtk-grass-bridge/source/browse/trunk/WPS/GrassModuleStarter.py
It is designed to be called from WPS server.
Best regards
Soeren
-------- Original-Nachricht --------
> Datum: Sat, 30 Jan 2010 15:13:08 +0800
> Von: maven apache <apachemaven0 at gmail.com>
> An: grass-user at lists.osgeo.org
> Betreff: [GRASS-user] stable java library for grass
> hi:
> I want to know is there a stable java library for grass?
> I want to call grass do some processes (for example r.buffer and etc..) in
> my java web application, and I nowtime I have to set the complex
> environment of grass in the java code for using grass, I wonder if there
> is
> a easier way?
Sicherer, schneller und einfacher. Die aktuellen Internet-Browser -
jetzt kostenlos herunterladen! http://portal.gmx.net/de/go/atbrowser
