[GRASS-user] Location wizard error
    Gilbert Ferrara
    gilbertferrara1974 at gmail.com
    Mon Feb 22 10:30:13 EST 2010
> In general don't be surprised if a generic linux build doesn't work
> properly on Ubuntu (or other distro) as location of system support files
> move about in an uncontrollable way.
To avoid this kind of problems, what is your suggestion in order to update
GRASS, using weekly snapshots?
> On Ubuntu 9.10/Karmic with the "proj" package installed the path to the
> EPSG file is "/usr/share/proj/epsg".
> I've got the UbuntuGIS grass 6.4.0rc5 on ubuntu 9.10 running here, and
> the location wizard looks fine.
> Mine is pointing to: /usr/local/share/proj/epsg. I changed to your path and
it worked. Question: Where do I define this path in order to change it
automatically when I install/update GRASS?
> Hamish
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20100222/2f15e4b3/attachment.html
