[GRASS-user] r.to.vect Produces Too Many Areas
    Rich Shepard
    rshepard at appl-ecosys.com
    Mon Feb 22 15:12:12 EST 2010
   I've done something incorrectly but cannot find what that is.
   Ran r.water.outlet and produced the output basin map. Then I applied
r.null to that map setting nulls to zeros. Next I applied r.to.vect to that
map (with the '-s' option) setting feature to area.
   When I look at the aspect map overlaid by the sub-basin map I see the 5
extraneous cells that should not be there. You can see them on the attached
screen shot.
   This did not happen the last time I used r.water.outlet, and the drainage
map does not suggest to me why these 5 cells are included.
   Help would be appreciated in learning what happened and how to get this
tail off the map.
Thanks,
Rich
