[GRASS-user] r.to.vect Produces Too Many Areas
M S
mseibel at gmail.com
Mon Feb 22 15:17:24 EST 2010
Since now a vector, can you select and delete those extraneous blocks?
Mark
On Mon, Feb 22, 2010 at 3:14 PM, Rich Shepard <rshepard at appl-ecosys.com> wrote:
> I've done something incorrectly but cannot find what that is.
> Ran r.water.outlet and produced the output basin map. Then I applied
> r.null to that map setting nulls to zeros. Next I applied r.to.vect to that
> map (with the '-s' option) setting feature to area.
> When I look at the aspect map overlaid by the sub-basin map I see the 5
> extraneous cells that should not be there. You can see them on the attached
> screen shot.
> This did not happen the last time I used r.water.outlet, and the drainage
> map does not suggest to me why these 5 cells are included.
> Help would be appreciated in learning what happened and how to get this
> tail off the map.
> Thanks,
> Rich
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
