[GRASS-user] HDF-5 parse
Markus Neteler
neteler at osgeo.org
Tue Feb 23 05:11:25 EST 2010
On Tue, Feb 23, 2010 at 10:16 AM, Pedro Roma <pedroroma1982 at gmail.com> wrote:
> By using
> gdalinfo HDF5:"/mnt/GIS/DATA/HDF5_DATA_MSG_FAPAR_Euro_200702220000"://FAPAR
> I get:
> Driver: HDF5Image/HDF5 Dataset
> Files: none associated
> Size is 1701, 651
> Coordinate System is:
> GEOGCS["WGS 84",
> DATUM["WGS_1984",
> SPHEROID["WGS 84",6378137,298.257223563,
> AUTHORITY["EPSG","7030"]],
> TOWGS84[0,0,0,0,0,0,0],
> AUTHORITY["EPSG","6326"]],
> PRIMEM["Greenwich",0,
> AUTHORITY["EPSG","8901"]],
> UNIT["degree",0.0174532925199433,
> AUTHORITY["EPSG","9108"]],
> AXIS["Lat",NORTH],
> AXIS["Long",EAST],
> AUTHORITY["EPSG","4326"]]
> Corner Coordinates:
> Upper Left ( 0.0, 0.0)
> Lower Left ( 0.0, 651.0)
> Upper Right ( 1701.0, 0.0)
> Lower Right ( 1701.0, 651.0)
> Center ( 850.5, 325.5)
> Band 1 Block=1701x1 Type=Int16, ColorInterp=Undefined
> Metadata:
> FAPAR:CLASS=Data
> FAPAR:PRODUCT=product
> FAPAR:PRODUCT_ID=0
> FAPAR:N_COLS=1701
> FAPAR:N_LINES=651
> FAPAR:NB_BYTES=2
> FAPAR:SCALING_FACTOR=10000
> FAPAR:OFFSET=0
> FAPAR:MISSING_VALUE=-10
> FAPAR:UNITS=N/A
> FAPAR:CAL_SLOPE=1
> FAPAR:CAL_OFFSET=0
> If I do :
> gdalwarp
> HDF5:"/mnt/GIS/LSASAF/HDF5_LSASAF_MSG_FAPAR_Euro_200702220000"://FAPAR
> /mnt/GIS/testing.tif
> I get:
> ERROR 1: Unable to compute a transformation between pixel/line
> and georeferenced coordinates for
> HDF5:/mnt/GIS/LSASAF/HDF5_LSASAF_MSG_FAPAR_Euro_200702220000://FAPAR.
> There is no affine transformation and no GCPs.
Since this is a GDAL problem, please ask on the GDAL list.
Did you try the MODIS Reprojection Tool? Does that fail as well?
Markus
