[GRASS-user] r.watershed: Interpreting Visual Output Map
Rich Shepard
rshepard at appl-ecosys.com
Tue Feb 23 14:28:26 EST 2010
On Tue, 23 Feb 2010, Markus Metz wrote:
> Almost right. ...with surface flow accumulation between 0 and the threshold
> value.
Markus,
Now I understand, yet still miss the difference between the accumulation
map and the visual map.
> All flow accumulation values larger than the threshold value are set to the
> threshold value.
Got that from the man page.
> Number of cells draining through a given cell. Converted to squared map
> units by multiplying with nsres * ewres, of the flow accumulation map of
> course, and first setting the computational region to match the flow
> accumulation map with g.region -p rast=<my_flow_acc>. -p to check that
> everything is all right.
I assume that the above calculation is left for me to do; that the
module does not do the math before displaying the results. Am I correct in
my assumption?
One last point: why no color in the legend? There is color on the visual
map but not on the accompanying legend. Strange and I don't know how to fix
this.
Many thanks,
Rich
